Username: Poof Post Number: 19 Registered: Apr-05
Saturday, May 07, 2005 - 15:38 GMT hey i have 2 alpine r type 1242 d subs 200-500rms 1500 watt max and i have 3004 left over to get a starter amp and i will upgrade later but i wouldlike to ahve some sugestions?
Username: Alpineuser Winchester,
TN
Post Number: 280 Registered: Mar-05
Saturday, May 07, 2005 - 21:48 GMT what?
Username: Poof Post Number: 20 Registered: Apr-05
Saturday, May 07, 2005 - 22:47 GMT i need some sugestions of amps less than 300$ that can power 2 alpine r type 1242d subs
Username: Taylor17 Kopperl,
Texas
Post Number: 1771 Registered: Jan-05
Sunday, May 08, 2005 - 02:30 GMT Hifonic's BX1500D is you're best bet, as long as they can be wired at 1 ohm, then each sub will get 500 watts.
Texas
Post Number: 1772 Registered: Jan-05
Sunday, May 08, 2005 - 02:31 GMT Correction, as long as it can be wired to 2 ohm's, not 1.
TN
Post Number: 281 Registered: Mar-05
Sunday, May 08, 2005 - 10:54 GMT no you where right the 1242 is dual 4 ohm so he will need a 1 ohm stable amp for the best sound and the brutus is 1 ohm stable
