How do i install door speakers in a 98 chevy 1500?
it doesnt have power windows or power door locks. basicly i cant figure out how to get the freaking panel off the door so i can get to the speaker. should i just try to rip it off? haha
Username: Kklagge
Post Number: 121
If you're having trouble getting the window crank off (assuming it's the kind that has the clip holding it on and not a screw or something) use a thin rag to get it off (grab the rag on both ends and slide the middle in behind the window crank and the door panel...pulling down on the rag while moving it back an forth to catch the clip...you may have to pull upward depending on which way the clip is situated).
no man its the whole door panel. i cant get any of the door panel off.
Username: Kklagge
Post Number: 127
there's got to be a few screws or bolts....I believe the door panel lifts up and not off (my 2001 Silverado panel slides up when you get a couple of bolts off)
