new mtx
Username: Ucfsaxman
has anybody heard any of the new mtx thunder 8500 or 9500 15's or any size for that matter.
Username: Insearchofbass
Post Number: 1868
i havent but my ive heard the 9500's a decnet but for the price id look at other speakers to be honest with you.....400 bucks can buy alot of speaker....what type fo sound are you looking for sq or spl or a mix?
Post Number: 1869
sorry for the typos
Username: Ucfsaxman
Post Number: 7
ya i'm really basically looking for a couple of 15 subs w/ real good sound quality but will also get good and loud to go w/ my rockford bd1001 amp.
Post Number: 1876
is this the one you mean?
http://www.rockfordfosgate.com/products/ez2rockford/ModelInfo/ModelInfo.asp?Item Key=10063516&CategoryDesc=Power%20Amplifiers
Username: Taylor17
Kopperl, Texas
Post Number: 1774
How much money are you wanting to spend?
Post Number: 1877
you can go with these they are the new hot topic here but im not sure of the coil ohm rating the atlas or the avalanch
http://www.ascendantaudio.com/index.htm
Username: Ucfsaxman
Post Number: 8
the amp is like the 2003/2004 model i think, it's the light gray w/ the blue symbol in the middle(the ugly ones)i'm willing to spend a good bit. i was considering the w7's but don't think that would work best w/ my amp.but the price wasn't the problem
Username: Taylor17
Kopperl, Texas
Post Number: 1781
You're amp will push a 13w7 fine.
Username: Ucfsaxman
Post Number: 9
thats what i was hopping but some others were saying no. so i didn't know what to believe
