Can I push 4 (4-ohm)speakers with a 2 channel amp?
Username: Calaway
Austin, TX
Post Number: 58
thanks ahead of time.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1180
Yes, if its stable to 2 ohms.
Just wire 2 in parallel to each channel.
-Fishy
Username: Calaway
Austin, TX
Post Number: 59
So if I got a 100x2 at 2ohm stable amp and wired in parallel, all speakers would get 100watts or 50?
Username: Fishy
Post Number: 1185
If its 50x2 at 4 0hm, 100x2 at 2 then each will get 50 watts.
-Fishy
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 766
wait a sec Fishy...
if he has four 4ohm speakers and wires em all in parrallel, that will be a 1ohm load. So a 2ohm stable amp wouldnt work in this case.
something like an orion hcca G4 would work though. they are 1/2ohm stable.
marcos61
but if hes running 2 (4ohm) to each channel(2)that would make it 2ohms to each channel, 50x2 at 4ohms, 100x2 at 2ohms, when wired 2 to each chanel, each would get half (50)
~marcos
Username: Fishy
Post Number: 1205
Yeah I hope he's not thinking about bridging a 2 channel amp into a 1 ohm load.
That wouldn't be good.
-Fishy
