Sean Box Help
Username: Algirard1
OH United States
Post Number: 110
I finally ordered my 15" Atlas. It will be running off a the rear channel of a Kicker KX650.4 bridged that will give the Atlas 325 watts rms. I am putting the atlas in my 1993 ford ranger extended cab. I was thinking of going ported to get the most output. My max diminsions are 40Lx20Hx12D. Can you help me design a box? I listen to mainly rap and then some rock. I was thinking of a tune around 30. Thanks for the help!
Username: Insearchofbass
Post Number: 1826
as far as im told about those subs its best not to put them in a ported box because of their design do the recommended sealed enclosure ...from what im hearing youll be very pleased and have alot more room in your truck lol
Username: Algirard1
OH United States
Post Number: 111
What box would you suggest?
Post Number: 1827
i have no personal experience with the sub but i believe james does give him a hollar and im sure he will help you out
Username: Algirard1
OH United States
Post Number: 112
ok thanks
Post Number: 1828
yw i wanted you to go with him because he has an idea what the sound characteristics would be in a specific size sealed enclosure
