Hey everyone, Is 2 awg good enough?
Username: Hellbender
Los Angeles, California USA
Post Number: 67
I plan on using 2 amps, one with 125x4 Watts rms going to mids/highs and a sub amp pushing 700-900 rms so about 1400 watts rms at the most. Can I use 2 awg for this or should I run 1/0 awg for my power wire? This will be going to a D-block where it will split to 4 awg wire to each amp. Also should I match my chassis,alternator and engine wires with the same gauge as my power wire? Thanks
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1222
I had to "upgrade" my power wiring when I relocated my cap. I could have just used 4 gauge, but found that I could get 1/0 from Knukonceptz for less than what many stereo shops charged for their 4 so I went with it. 2 gauge is plenty for what you're doing, but 1/0 is only $2.25 a foot from Knukonceptz.
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL1/0BL
If you don't mind waiting about a week for delivery you might want to get the big stuff. The extra wait would probably be worth peace of mind.
-Fishy
Post Number: 70
Cool, thanks Fishy :-) I think I'll get the 1/0 gauge in that case.
