Subfantic about the epic 160 and bass cube
Username: Insearchofbass
Post Number: 1799
ok so as i said the epic 160 is able to go up to 160 db and it has a built in spl mic and displays in digital readout it also shows voltage in digital readout as well its basically a phoenix gold bass cube with those extras 190 bucks
http://www.cbrstereo.com//index.asp?PageAction=VIEWPROD&ProdID=646
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=1498%26item%3D5771585176% 26%26 (this also comes in black i have one i never hooked up looks nice)
the phoenix gold bass cube is a device that can mount in your glove box and has a dial to find your best hit frequency and get the most out of your subwoofer with your amp...it also has an on off nob if you dont want to use it and just run as if you dont have it it can be boosted by 15 db i think but realistic gains can be from 1 to 11 db according to the shop i worked at that installs them 11 db was theyre personal best gain after installing it my buddy has this in his blazer and gained about 3 db with it that costs about 130 bucks on ebay
