Wiring a 4 Ohm DVC to a 4 OHM VC
Username: Nihilicide
I'm going to be hooking up an Infinity 12 DVQ 4 ohm dual voice-coil sub along with an Infinity perfect 10.1 4 ohm sub to a Kicker 600.1. If I wire them up normally, it'd give a 1.33 ohm load...not good.
Is it okay to hook up just ONE of the voice coils on the DVQ, so it's just 4 ohms, then the 10.1 is 4 ohms, so I'm running a 2 ohm load on the amp?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 768
dont mix subs w/ different voice coils...it just doesnt work that way.
Well, electricity *does* work that way, but that wasn't my question. I just want to know if you can hook up just ONE of the voice coils on the dual voice coil amp to make it 4 ohms instead of 2?
Username: Audiophile
OFallon, MO USA
Post Number: 130
What he's trying to tell you, and so am I, is that it isn't a good idea. Besides that, you shouldn't mix subs period. All subs dont sound the same, nor do they have the same power handling, etc... That's gonna be one phucced up system if you ignore the advice given
the 10 inch sub is in a custom enclosure between the driver/passenger seat. the 12 will be in the trunk. I'm just going to get another amp.
Big D
if you gotem, amp em....wire it parelel-series
it is against "audiophile" practices, but like I said AMP it if you got it
OFallon, MO USA
Post Number: 135
...I really hope "Big D"is a troll. WTF is parelel-series wiring? Parallel OR Series is one thing, but I'm not quite sure what it is you're trying to get at here.
If you're bent on using both subs, I reccommend getting 2 amps. If I were you, I would just get another 10" kappa perfect. I have a DVQ and they sound great, but the Kappas are better.
Username: G3nocd3
San Jose, Ca USA
Post Number: 9
IT WILL SOUND LIKE STRAIGHT S$#T. Trust me. Dont mix sizes and sub brands. Even different sub models from same brand. Each sub is unique with its q. In other words how accurately it hits the with actual music. If you mix a 10 and a 12 they wont drop at the same time. So do your self a favor, save up and buy a 2nd 12 or a 2nd 10. Dont mix subs. and you will be fine. Oh also if you mix an uneven ohm. like a 4 ohm dvc and a 2dvc it will make power unstable which can equal blowing the subs and frying the amp.
