Kicker l7
CDS254
I was thinking about getting a 15" L7 and put them in a ported box with 100 watts running to them. Do you think if i send 1300 watts it may be too much or will it take it? Also will that hit really hard or just decent?
CDS254
thats 1000 watts not 100
Username: Insearchofbass
Post Number: 1685
no need to do the 1300 if were talking rms power as compared to 1000 rms the db you gain would be no more than 1 id think and yes you would damage the l7 15 with 1300 rms for daily use
Username: Car_bangs
Post Number: 33
im running 1200 rms and have no distortion doesnt seem like they are stressing kickers can take a little more than they say. it will hit hard and still sound like shizit. i agree with sean 1300 daily use would damage your kicker in the long run what amp r u running
CDS254
hifonics BX1500d
Username: Taylor17
Kopperl, Texas
Post Number: 1682
It should be fine, just watch you're gain.
