I NEED HELP FAST PLZZZZ
Username: Poof
Post Number: 23
hey i need to know how i can hook up a HiFonics BX1500 d amp to my factory radio in a jeep liberty limited 2002??????? i have no clue how i can hook this up without getting a new radio and i dont want to get a new one someone plz help
Username: James1115
Wilton, Ct
Post Number: 2800
you need a LOC it coverts your speaker wires into a RCA connection to run signal to an amp.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 390
A new deck would help alot.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1224
I vote for a new deck also.
Even a bottom of the line $50 jobby will sound better than an LOC, as long as it don't break on you.
-Fishy
Username: Zero43
Kyle, TX USA
Hey man I have an 01 jeep cherokee. And believe me you would be best to just get a new deck their not that hard to put in. Much easier than figuring out how chrysler color codes their speaker wires I will tell you that much.
The only hope you have is to bring all the speakers out in the open an write down the colors of the wires and then match them up at the head unit. then either run speaker wires all the way to the amp or like the rest said get an Line out converter
Username: Zero43
Kyle, TX USA
oh and i forgot to mention in case your speaker leads arent labled or color coded the fat lead is the positive
