CrossFire VR1000D / who has one or knows about it?
Username: Suleman36
Post Number: 1079
Since i sold some of my amplifiers that i had no use for i decided to find a amplifier to suit my Avalanche 15. At first i wanted a Orion HCCA 250g4 but had no luck finding one. So i did alittle research and decided to order a CrossFire VR1000D mono amp thats gonna be run at 1000 watts rms X 1 @ 1ohm tested at 12.5 volts and over 1100 at 14.4 volts. I read nothing but positive things about this and i look forward to getting it. I found one brand new at http://www.caraudiomag.com/specialfeatures/0202cae_amp/
Username: Suleman36
Post Number: 1080
anybody else own this amp?
Username: Carguy
Post Number: 2796
MO crossfire is a good amp. I wouldn't say it's as good as Zapco nor JL, but better than few others.
There isn't whole lot of info on crossfire, even their manual omits certain information.
I think overall, you should be happy with it.
FYI, class AB amps's efficiency gap with class D, narrows as you near max output.
Username: Suleman36
Post Number: 1082
Isaac, i look foward to this amplifier cause im pushing that Avalanche 15 with it. Its gonna hit hard as hell. I better stay with 2.2 cubes huh other wise my midrange may get overshadowed with 2.5 cause of the lack of top end and strong low end.
Username: Carguy
Post Number: 2798
High quality bass will always enhance the sound. Most of the time when bass overpowers the mids and highs is due to low quality SPL/bass setup.
Username: Suleman36
Post Number: 1083
so this is low quality????? what im using..lol I think 2.2 cubes with 1lb of polyfill sounds like a winner.
Username: Carguy
Post Number: 2801
No, what I"m saying is that, lot of people who complain about bass overtaking their mids and highs, tend to have terrible bass sound quality to begin with.
Username: Suleman36
Post Number: 1084
I ordered all my wiring from knukonceptz and now i need to get speaker baffle for my componants from that site.
