Recomendations please...
Username: Aidy
I have recently purchased a Kenwood KDC-W6031 Head unit and a set of Alpine SPS 690a 6x9 speakers. I am looking for an amplifier to improve the quality of sound and give a boost in volume. I was wondering if you would be able to help recommend me one.
Thank you very much.
Aiden Lennox
Username: Byrumjr
Post Number: 211
If you just want to run the 6x9's.You want to look at the RMS watts for your 6x9's and the ohms of each. Match the amp to that. Most likely they are 4 ohms each. Some speakers just have the max watts. RMS will be half of the max.
Username: Aidy
I don't know much about Car Audio. Here Are the specs. Is there any chance you could help me out?
Thanks for your help.
Features:
Power Handling Capacity (Peak) : 250W
Power Handling Capacity (RMS) : 50W
Frequency Response : 30Hz - 30kHz
Impedance (Nominal) : 4 ohms
Magnet Weight : 375g
Mounting Depth (in) : 2-3/4"
Mounting Depth (mm) : 79.4mm
Mounting Diameter (in) : 5-39/32" x 7-24/64"
Mounting Diameter (mm) : 150mm x 200mm
Sensitivity : 92 dB
Tweeter Height (in) : 3/4"
Tweeter Height (mm) : 19mm
Tweeter
9mm Balanced Dome Tweeter
Ceramic Magnet
Midrange
60mm Pulp Cone
Strontium Ferrite Magnet
Woofer
Rubber Surround
Spoke Design Grill System
Titanium Coated Cone
Thnks again Aiden.
