What is a good amp for 60a fuse rating?
Username: Dano9258
Post Number: 11
I need help plz! I bought the new infinity 1211a amp only to find out that it take 120a. I cant have that high of a fuse rating. Does anyone know of a great amp with 60a fuse rating? I've got two audiobahn subs(12" 550 rms 4ohm svc), and i want a huge bass system for playing some hip hop music. THanks.
Username: Byrumjr
Post Number: 208
120 amps is a lot to run with other things in the car running too, but it can be done. I don't know if you will find an amp with 60 amps that will push both subs good. Bass notes take a lot of watts to reproduce. I would look into MTX amps.
Username: Dano9258
Post Number: 13
Thanks. I looked at them, and they are that great. The closest i could get is about a 600w at 2ohms. Im looking at boss or power acoustic right now. How could i do 120 amps with only a 105 alternator? (I dont want to replace the alternator).
Username: Sevin7
Post Number: 90
you cant. the most your going to get outta 60A is 600watts rms. If anything says its over 600RMS @ 60A its a lie.
Username: Byrumjr
Post Number: 212
Oh, 105 amp from alternator! You can't run a amp with 120 amps. On 60 amps at 100% your get near 810 watts. But no amp is 100% so with 60 amps and a good amp you might get 500 watts.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1137
I thought you bought a 1100 watt power acoustik?
How many amps you got anyways?
List em. Maybe one will work.
-Fishy
Username: Dano9258
Post Number: 25
I got my current rockford 6001bd(doesnt do crap), two infinity 1211a's and a power accoustik. But it doesnt look like any of them will work according to what all of you are saying. So im still looking for a good one.
Username: Sevin7
Post Number: 94
your not getting more than 600watts from 60A, just buy a new alternator.
Username: Calaway
Austin, TX
Post Number: 52
Yea my Fosgate p500.2 has 60a fuse. Good luck.
