Inline Fuse Question...HELP!!!
Username: Davidnolen
Lexington, South Carolina USA
Post Number: 12
I purchased a 800 Watt Mono Block, class D, same thing. I am running 8 gauge wire to my two 12 inch 450 watt subs now. Is 8 gauge fine? I also have a 30 amp inline fuse near my battery, should I get a bigger one. I blew the inline fuse on the way home from a friends house? Should I get a 60 amp inline fuse since my new amp has two 30 amp fuses? someone help me!!! LOL
Username: Dano9258
Post Number: 15
You generally want your inline to equal your amps. So if your amp has 60, get a 60 on the inline. But you also need to remember that most cars have a 105amp alternator and usually the other car functions take about 50amps. So your getting very close to maxing out your battery. Be careful.
Post Number: 13
But I'm better off getting a 60 amp, right? I dont want to mess up my car. I have 30 in there now, should I change it ASAP?
Username: Sevin7
Post Number: 91
yes you should, get a 60amp fuse. this chart also says 8 guage wire is fine for 60 amps, as long as its not too long. :
http://www.crutchfieldadvisor.com/learningcenter/car/cable_gauge_chart.html
