Using 1 sub in a dual sub box???
Username: Hmpadilla
Gilbert, AZ
Post Number: 27
I just posted a question about wiring a dvc sub.Have 1 more.Since I have a box for 2 subs and can't afford a new one,Can I purchase a qood quality dvc sub and wire the amp to this sub only,leaving my cheap sub to fill the other hole? My box has .79cu ft per side,but they are not seperated.thanks
Username: Solacedagony
New Jersey US
Post Number: 378
Yea sure, just leave the other sub in it, or even cover up the 2nd hole, and only run the one sub.
Username: Shouder
Wisconsin
Post Number: 132
it will work, but i would recomend getting a proper box with the correct volume dimensions when you can afford it. with the proper dim. you will be much happier with your subs performance. and im sure get plenty of bang for your buck.
