2 amps to one battery
dangles101
Im currently running a 1200w sony amp to power my 2 subs and i was wondering if i added a 2chanel(most likely 2x75w RMS) amp for my front components if that would be too much draw off the battery?
Username: Carguy
Post Number: 2759
Off the battery? How did you wire the amp? It shouldn't be connected directly to the battery anyways.
Once the car is running, the alternator supplies all of the power till demand exceeds supply. Only then the battery takes over.
You should be alright with 2nd amp. After all, you have a Sony amp, not like it's giving you 1200w rms.
dangles101
how should they be connected then? by not directly to the battery do you mean throught a capacitor or fuse?
