I was thinking about building my own amp kit. buying 4ga wire and putting a fuse in it myself. do you think this would be cheaper than buying one of those ready made kits?
Yes, it's always cheaper if you make your own. But don't expect hugh difference. The kits come with inline fuse+holder, rca cables, remote wire, power and ground. Some even give you end connectors.
