Ported Box for 1 12w6v2 / James or Jonathan
Username: Suleman36
Post Number: 1097
Hey james/jonathan or anyone else thats interested. I was gonna sell my 2 12w6v2's in the JL prowedge box but i may test one in a ported box before i decide to sell both. What whould be the best cubic ft and tune for a ported box for 1 12w6v2? i know james has tried it in both. let me know guys.
Also whould it be ok if i used my Zapco 500m that puts out 700 watts x 1 @ 2ohm ??? i know this sub takes 400rms.. Let me know
Username: Suleman36
Post Number: 1098
or should i test it with that CrossFire VR1000D mono amp that can also do 500 WATTS X 1 INTO 2 OHM @ 12.5 VOLTS . Let me know which amp to test it with aswell as the right ported box info.
Username: Suleman36
Post Number: 1101
jonathan or james?
Username: Subfanatic
Walton, Ky
Post Number: 3347
So im not good enough to help you, i see how it is.
But i would do 1.5 cubic feet ported tuned to like 28-34 hrtz somewhere in there, thats my taste if u ask me, but isnt its Fs 25, idk
Walton, Ky
Post Number: 3350
oh and i would test the 2nd amp, the crossfire
Username: Suleman36
Post Number: 1103
Yes its 25hz you got it.
here is the pdf http://www.jlaudio.com/subwoofers/pdfs/W6v2_MAN.pdf
Username: Suleman36
Post Number: 1104
So 1.5 cubic feet. I listen to mostly rap. I wanna maintain SQ / SPL so how does 30hz sound for the tune???
Username: Suleman36
Post Number: 1105
According to this pdf http://www.jlaudio.com/subwoofers/pdfs/W6v2_MAN.pdf
Im gonna go 1.5 cubic ft. tuned to 32hz.
Username: James1115
Wilton, Ct
Post Number: 2784
I would do 1.75 tuned to 30 htz if I were you. I did that same enclosure tuned to 27 and it sounded very nice.
Username: Suleman36
Post Number: 1106
James the pdf recommends 1.5 tuned to 32hz .
you say 1.75 which i could at 30hz? what is the major differance
Username: James1115
Wilton, Ct
Post Number: 2789
you will get a deeper response especially if you listen to Rap and electronica or whatever you listen to lol!
Username: Suleman36
Post Number: 1107
1.75 tuned to 30hz i will get a deeper response for rap then 1.5 tuned to 32hz ?
