WEIRD response
Username: Subfanatic
Walton, Ky
Post Number: 3304
guys whats the deal, i built the box to how i thought i should, and when i change tracks you can hear the bass hitting, and when i first turn on the car it goes BOOM BOOM!!!!, and what is causing this, i hooked up 2 different amps and it keeps happening????thanks guys, also i got it done, its like tuned to 48 hrtz i think and is decently loud, not what i expected. P00P
Username: Insearchofbass
Post Number: 1722
sub i told you if you build a box like this you cant use it for music without a swappable port
Post Number: 1723
the pop is probably due to hard start on your amp in other words not enough delay.....also if you ported to 48 hz you probably peak out higher than that like sa 50 some hz....you have to design the port tune lower to peak at the frequency you want.......for instance in the 4.29 cf box before displacements youd have to port to 42 hz to peak at 48 hz
Walton, Ky
Post Number: 3305
how would i cause another delay, and the box i dont think its tuned as high as i said, here its the those uh same dimensions, and i dont know what the displacement is, but the ports are like this, i used 4 ports, 2 are 4 inches long and 2 are 5 inches long, lol, so what would that tune that box to, and what can i do about the popping, its really weird, could it be due to bad wires or somen
Post Number: 1724
you cant port diferent lengths like that the should be even lengths
Post Number: 1725
sub at this point im not sure what your popping is unless its diffrent amps than you have used before and they dont pop on soft from factory or if its poor ground wires maybe
Walton, Ky
Post Number: 3308
ok what ifi do 4 4 inch ports and could the popping just be the rca running next to the power wire, im rewiring everything tom anyways
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 737
Welcome to the wonderful world of turn-on-pop. LMAO
My amp used to do that really bad...try checking your ground and make sure the RCAs are away from the power wires. Sometimes turn-on-pop is a b!tch to get rid of.
Walton, Ky
Post Number: 3309
yea it f()ckin sucks lol, but it also makes alot of bass while changing tracks, what is that????
by the way i changed all my ports so now i have 4 5 inch ports whats that tuned to??? lol
Walton, Ky
Post Number: 3311
bump
