Fiberglass mat and resin...sub
Username: Goon
Post Number: 157
I was told lining the inside of the box with fiberglass mat and resin would help sq. is this true? what are your thoughts? thanks again.
goon
Username: Subfanatic
Walton, Ky
Post Number: 3188
i think that is only to make sure its complete air tight
Username: Goon
Post Number: 158
damn. is there anythign liek that, besides polyfill, that i can do to improve the sound quality, or loudness. thanks for the help man.
goon
Username: Jonathan_f
GA USA
Post Number: 3806
Bracing helps due to the added rigidity of the enclosure. Fiberglass is used for both sealing the enclosure and also adding strength, especially in the corners. You could add sound deadening to the walls of the enclosure if you'd like, in addition to polyfill. You could also go aperiodic or infinite baffle :-)
Username: Goon
Post Number: 161
aperiodic? you will have to explain this a tad more, i'm sure what you are saying. if im going to build my box, i want to do it right. make it sound nice, sq wise. thanks again
goon
GA USA
Post Number: 3819
Here are some links describing aperiodic. Only works on cars with trunks unless you're into cutting holes in a car.
http://www.maximacar.com/aperiodic.htm
http://www.elitecaraudio.com/article.php?sid=18
You are using a resistive membrane to control cone motion, as opposed to an enclosure, your sub doesn't sound "boxed". Control is excellent, transient response is excellent, SQ is top notch, above sealed, ported, and so on due to the flattening of the resonance of the sub.
