Wiring Help
I have a Audiobahn A8000T and I have 2 10" 4 ohm dvc subs. I know I should have a 2 channel amp but I don't. What is the best way to wire them to get the most power? A diagram would be great.
Thanks
chris henryroo
in parallel is the best way. but you really need the JL audio 500/1 amp
Can I run a 1 ohm load on that amp??
Username: Glasswolf
Post Number: 1439
no you can't.
you need to wire the sub coils in series, then wire the subs to the amp in parallel for a 4 Ohm load.
that's the best you'll do.
the ideal solution is to unload that audiobahn stuff and pick up some better gear from a reputible company, like a Kicker or MTX amplifier, and some Adire, Elemental Design, or Kicker CompVR subs (two SVC 4 Ohm models)
