I have read good things about them MO let me know how it holds your system together. Did you ever decide to go with the HO alt or not? If not it will be interesting because with the system you are going to be running you will deff strain your electrical system so it will be a good test.
battcap's major drawback: high ESR, and too far from the amplifiers unless it's trunk mounted next to the amps. the capacitor portion should be right at the amplifiers.
James im gonna run my system with the orion hcca 250g4 and ppi art 300.2 and see how it handles and if i get heavy dimming then i will upgrade to the HO alternator.
James im gonna run my system with the orion hcca 250g4 and ppi art 300.2 and wire it close to the BatCap 800 and see how it handles and if i get heavy dimming then i will upgrade to the HO alternator.
