Comp CVR's(2005 model) good for budget?
Tom Tom
Is 2 12" comp cvr's going to be good for a budget of about 140$?? or is there going to be a RF/JL/Infinity i could get for the same price and be better
go w/ the older comp vr's...better subs and cheaper
95 mushroom
i have 2 15" 2004 comp VRs and they sound awesome with my Kicker KX1250.1
95 mushroom
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 337
Those are great subs for the price.
Tom Tom
so the older models are better then the newer ones?? that dosen't make much sense, you get better technology in a year or 2/ shouldn't the sub souond better and louder!?
So old vs New
or any other ideas for round 140
Tom Tom
areTWO (2) of the comps cvr (Silver-2005 model) going to be better then one (1)of these?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18803%26item%3D5770495070 %26
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 588
yeh two compvr's are will be louder than one alpine type r, depending on how you set it up. but they newer are better than the od ones. Not by much at all but if i remember correctly kicker says the upgraded the voice coils to the same kind they use on solobaircs, but dont quote that. I might be wrong.
Username: Subfanatic
Walton, Ky
Post Number: 3156
dude, get a 12 inch atlas, it will have much better sq, and better spl to, www.ascendantaudio.com but yea theolder ones are better, the new cones are made out of a new material that isnt durable. This is how i feel personally, and they look retarded, But i havehad cc guys (who know NOTHING) say that the new ones are better, I highly disagree
Tom Tom
so if i were to go with them, the older kickers are the ones to get?
i want 2 subs not just one, so any other ideas besides kicker?
Username: Jmloughrey
Farmington, CT
Post Number: 1250
single 12" orion HCCA...i'll sell you mine hahaha
Username: Creative
Newark, CA USA
Post Number: 14
I have two Kicker Comp VR 12" and I regret getting them in the first place. I should have gotten two Infinity Kappa Perfects. 12.1D instead. The 12.1D in my opinion has so much better SQ then the VR's in like everyway and the SPL is not that behind the VR's.
Walton, Ky
Post Number: 3181
yea infinitys are hard to match sq lol
Tom Tom
but the inifinity's aren't in my budget... but arent the new kicker comp cvr's like 400w rms, n the older ones 150w rms?? and if you could find a website where i could get the comps because im still not positive what kind you guys are talkin about
Username: Ctx
Post Number: 124
Lets put it this way, if you put them in a good box, with the right power you WILL NOT regret buying them for the price, no matter what these people say. Ive heard many of these subs and there great for the price. btw from what ive heard there is no audible differnce in the new and old cvr's
