Bronze Member Username: 1stimerPost Number: 31 Registered: Mar-05 | What would you guys choose for this budget?...don't mind going used...e-bay is my friend...I have image dynamics 5.25 up front powered with 100x2 arc audio amp. Needs to comply with a whimpy alternator. one choice I came up with---idq-10 dual4ohm with jbl bp300.1. Any other combos you guys can suggest?? |
Gold Member Username: James1115Wilton, Ct Post Number: 2666 Registered: Dec-04 | Atlas 12 if you would consider a 12 and a PPI a300. |
Bronze Member Username: 1stimerPost Number: 32 Registered: Mar-05 | ty James....I would consider a 12...hmm ppi for a sub....never thought of that....don't think it would be a waste to run it for subs? just worried about my alernator, but with two pretty low powered amps, I bet I would be ok. Any other combos guys? |
Gold Member Username: James1115Wilton, Ct Post Number: 2679 Registered: Dec-04 | I have a PPI a600.2 and I have run multiple different sets of subs with it and it ran them all flawlessly with great precision and detail![]() |
Bronze Member Username: 1stimerPost Number: 33 Registered: Mar-05 | Remember the budget is $250 for the sub AND the amp. Don't think either of your combos will fit into that budget. The jl blows that budget by itself. Anyone got a good combo for $250 or less? |
Bronze Member Username: 1stimerPost Number: 34 Registered: Mar-05 | Take that back James...A used 250/1 can be had for around 175 or so it looks like, so you might not be too far off afterall. I like the ppi route better though. I am going to try and listen to some subs today. Thanks again. Keep anymore $250 sub and amp combos coming please. |
Gold Member Username: James1115Wilton, Ct Post Number: 2690 Registered: Dec-04 | http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26%26item%3D7970445635& category=38638&sspagename=WDVW that should not go much higher! |
Bronze Member Username: 1stimerPost Number: 36 Registered: Mar-05 | Thanks James....not too confident with that feedback, but I did grab this pc275, which seems to have the same specs. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5769992514 |
Gold Member Username: James1115Wilton, Ct Post Number: 2720 Registered: Dec-04 | thats a nice amp as well but not as good as the art series in my opinion! I know Isaac feel's differently but I have a thing for the art series amps, they are absolutely fantastic amps. |
Bronze Member Username: 1stimerPost Number: 37 Registered: Mar-05 | I think I did good for the price. Here is a price list of older PPI amps I found interesting. http://66.102.7.104/search?q=cache:47T_wL2ZkaAJ:www.precisionpower.com/ppipdfs/g eneral/retail1.pdf+pc275+ppi&hl=en |
Gold Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 1089 Registered: Sep-04 | That amp would go well with an Atlas 12. Oh, here's another good pdf to go along with that one: http://www.precisionpower.com/ppipdfs/general/lineage.pdf I paid lil over $800 for my pro MOS 2050D in '89 so those prices are pretty reflective of what that stuff was going for. -Fishy |
