Wiring subs
Username: Northerncomfort
Sudbury, Ontario Canada
Post Number: 11
what would be the best way to wire 2-10inch subs(4ohm single voice coil)to my amp???
amp specs-1 x 760 watts (2-8 ohm acceptable)
2 x 250 watts (4-8 ohm acceptable)
not sure if i should wire them together or on seperate channels??? which way would be better???
Username: Taylor17
Kopperl, Texas
Post Number: 1586
Bridge, and wire in paralel. If I'm reading that right, it should put out 700 watt's at 2 ohm's. Asuming that that is rms ratings.
