2 10" Diamond Audio Subwoofers!!!!!!!!!!!!!!!
Username: Robste15
I was wondering what would be a good mono-amp to run 2 diamond audio subs that have 4ohm dvc and are rated at 500 rms each?
Username: James1115
Wilton, Ct
Post Number: 2504
JL 1000/1
Username: Robste15
should i wire the 2 subs in parallel to drop the ohm to 2ohm or is there other wiring options that would be better with the amp?
Username: James1115
Wilton, Ct
Post Number: 2507
run them in series at 4ohms to that amp they will sound great.
Username: Robste15
Thanks man :-)
Username: Subfanatic
Walton, Ky
Post Number: 2798
yea run them in para/series like james is saying, cuase u cant wire them 2 2 ohms
Username: James1115
Wilton, Ct
Post Number: 2509
no problem dude
Username: Robste15
What's the cheapest place to buy this jl amp? All the places i looked are wanting it for around $799 :s
Walton, Ky
Post Number: 2862
yea, its a VERY EXPENSIVE AMP, id get somen else personally lol
Username: Robste15
Post Number: 8
well i was looking at getting the Kenwood Excelon KAC-X810D mono class "D" amp rated at 1000watts rms x1 @1ohm since i think im going to run those 2 dvc 4ohm subs in parallel which should drop the ohm impedence to 1, do know if that would be an efficient amp to run these 2 diamond audio CM3 10D4 subs?
Walton, Ky
Post Number: 2867
if u need a good cheap amp, hinfoncs has a 1000bd amp that is 1000 watts rms at 1 ohm
Username: Robste15
Post Number: 9
thx ill check that one out!
Username: James1115
Wilton, Ct
Post Number: 2540
do not run a hifonics amp to those subs. buy Mo's PPI pcx 2200 that amp would be perfect for you.
Username: Robste15
Post Number: 10
that would be a perfect amp cuz its rms is 800x 1@4ohm that should be plenty to power 2 500 rms subs because im looking for SQ/SPL.
Username: Robste15
Post Number: 11
See i figure putting those 2 10" diamond audio subs because i found them for $99 a piece and running them in a custom "downfire" box under my backseat of my chevy silverado would that give me good SQ/SPL?
Username: James1115
Wilton, Ct
Post Number: 2541
yeah they will sound good, I would contact MO and see if you can get that amp from him.
Username: Disturbedpriest
Post Number: 76
onlinecarstereo has them for 99 is that where you found them at?
Username: Robste15
Post Number: 29
yeah the diamond audio cm3 10d4's i found on onlinecarstereo for $99 a piece
Post Number: 79
not bad, they are a good company it seems i bought some dynamat from them and my dad bought a jlw6 and some components from mb quart off their site..
Username: Robste15
Post Number: 31
yeah i haven't bought them yet but im really thking about it though cannot go wrong with that price, i think im going to buy 2 of them so they should sound pretty good
Post Number: 91
Hey robert let me know what those subs sound like when you get them i want to put two of those in my wifey's truck because she bought crappy aass audiobahns... now ig otta sell them and get her something else.. god they sound like total arsee.
kiklir
does audiobahn amps suckass
Username: Robste15
Post Number: 38
aight ill let you know
