Need Help Choosing Amp!
Username: Jboss
i have 2 4 ohm 10" sony subs with 150rms and 650peak...i dont have much money to spend on an amp right now (like a $100 <) what is the min sized amp i can use with these....
Username: Insearchofbass
Post Number: 1646
almost anything will work on them...ill see what i can find for you
Username: Carguy
Post Number: 2661
If your subs are 150w rms each, then you will need 300w rms amp that is 2ohms stable. I'm guessing since it's a Sony, the subs are 4ohms SVC.
Post Number: 1647
something like this would work on them
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39735%26item%3D5770170347 %26
Post Number: 1648
opps no no no dont get that wrong ohm load
Post Number: 1649
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796%26item%3D5769412411 %26
heres one you can try 150 rms at 8 0ms which you can wire them up that way ...ill see if i can find anything better
Post Number: 1650
8 ohms bridged is what i meant to say
Post Number: 1651
I bought my cousin the lower model of this amp and were pleased with its performance....it should run very cool at 8 ohms and power your 10s well
Post Number: 1652
actually i just realized you meant they handle 150 rms each .......do this amp .....its stable at 2 ohm and will put out 350 x1 which is fine ...a little over the rated rms of a speaker is fine
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5769513791 %26
Username: Jboss
Post Number: 7
yo thax lot..thos ones look descent....just what i was looking for..
Username: Jboss
Post Number: 8
just to be sure....wat ever amp i choose...the rms has the be close to matching up with the combined rms of my subs?
