Whats the Best outta these
Jake Reed
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777%26item%3D5769132239 %26
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39778%26item%3D5769185684 %26
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39779%26item%3D5768259959 %26
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39776%26item%3D5769556141 %26
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48614%26item%3D5768728034 %26
Whats going to be the best set of subs outta all of these, any other suggestions would be good
also any ideas on cheap amps?
Username: Subfanatic
Walton, Ky
Post Number: 3063
infinity's, but what is your price lmiit
Jake Reed
160 max... lol im not proud of it but if i want to get a decent amp thats about all i can afford
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18803%26item%3D5770312454 %26
1 of those??
1 of those?( i am OKAY with only 1 sub but i would really like to have 2, and whats your recomendation in my price range of 160$)
that one^--- haha i really have no idea, all i know is 160 is my limit so if you got any better ones please tell me(160 includes shipping on the items too, so probably around 130-140ish)
Jake Reed
are the infinity's that much better then the RF's and Kicker comp vr's/ because i've heard alot of good things about those brands and heard just abou;t nothing on infinity's
Walton, Ky
Post Number: 3085
they arent that better, but the sq will easily beat them out
Jake Reed
are any of those 1 subs be better then 2 of the ones at the very top^^, also there were some 10 and 12" RF Ti's for about 150$ for 1 would those be better then these?
and anything better then the names i named allready for 160 and under(INCLUDING THE SHIPPING CHARGES) please let me know ASAP
Walton, Ky
Post Number: 3089
yes they would be
Jake Reed
so then all 3 of those 1 subs are going to sound better, and louder then 2 of the subs at the top... what would you do in my situation!?(and get more money ain't a option ;) which brand sub for about 150 (besides the atlas) and what type amp to go with it
p.s. what do you mean by "yes they would be" i have like 3 different questions which one did you answer--haha look forward to looking at your suggestions
Walton, Ky
Post Number: 3098
your first quesition 3 posts ago, if u can get a T1 Rf, for 150 bucks, that would dominate all of those subs at the top in spl. but in sq the infinitys would beat them, not many better sounding subs than infinity's to name the ones i know of, the eclipse al line, the w6v2's, idmax's, i like my Ti(not T1, T1 is made by RF, Ti is made by eclipse) more, and supposedly the atlas, no personaly testing YET.
Those are some good subs, and no the infinity's would not be that much better, the kickers would have very similar spl the rockfords would be fall a little behind, but the infinity's would tear them all away.
May i ask why you will not get an atlas, i highly reccomend it. after we pick you a sub, and everything THEN we will look at amps with your budget because before that we wont know what ew need. lol i hope this helps
Username: Jwbulger79
Florida
Post Number: 517
http://www.caraudiocentral.net/forums/showthread.php?t=845
Jake Reed
The only reason im sceptic on getting just 1 atlas is i want to be HEARD, not like overpowering or anything but i just want to roll up to someones house and know im there just because they can here me coming... is 1 300w rms atlas going to be able to do that?? and do you recommend the 12 or 15
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 331
get two subs at $80 a piece. Kicker comps or compvr's maybe.
Walton, Ky
Post Number: 3110
no, the atlas will beat 2 kicker comp vrs in spl, and will DEMOLISH them in sq, we have debated this before, i won, the 1 12 atlas will beat 2 12 comp vr's
