Which amp is better
Username: Cenus
Hicksville, Ohio Usa
Post Number: 67
which amp would be better 2 push 1 15inch avalanch http://www.woofersetc.com/product.asp?0=362&1=363&3=2168 mtx t801d or http://www.woofersetc.com/product.asp?0=362&1=363&3=131 mtx 6500d
Username: Subfanatic
Walton, Ky
Post Number: 3050
niehter lol
Username: James1115
Wilton, Ct
Post Number: 2604
go with either the kicker you origanally planned on or Orion HCCA 250g4, Orion 2250sx,Jl 1000/1 all three of those will rock it very nicely:-)
Username: Cenus
Post Number: 68
cool thanks
Username: Cenus
Post Number: 72
ok i got some more choices would a kicker kx 400.1 be enough to power the avalanch or should i get the kicker kx600.1 the reson im asking is because i can save about $150 by getting either of those amps instead of the kicker kx850.2 that i had origginally planned for
