What does deep cycle mean?
batt
hey i've read alot about deep cycle batts, and marine batts, but what does deep cycle mean? does it mean you can run your battery all the way down and still be able to start your car? if thats true how long does one deep cycle batt last?
Username: Lotus
Post Number: 9
www.optimabatteries.com
check out their batteries, they have plenty of info and are worth the $_$
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1044
Deep cycle means that you can completely discharge/charge or "deep cycle" a battery w/o seriously damaging it. This type of use is awfully hard on your typical automotive starting battery.
-Fishy
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7803
http://www.wickedcases.com/caraudio/batteries.html
that's what ya need to know.
just a bit more on what Fishy already told ya
