Amp need for (2) JL Audio 12w6v2
T May
Which do you insist: using a mono amp to run both subs or a seperate amp for each sub? What is the difference? What amp(s) would you use? I am lookin to spend no more than $500-$750 on amps!
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 276
okay get a JL 1000/1 which will cost you close to that $750 ... there really isnt a better choice when you think about it. great amp, great looks, great match for the subs. i know the w6v2s are 400 rms but many ppl have applied a 1000/1 to 2 of them and sound great.
Username: Loc_out
Post Number: 86
go with a 1000/1
