6x9's Alot better then 6/12??
Username: Alex_ochoa
Tucson, AZ USA
I have a 98 altima and my rears are 6 1/2. I Want to buy the infinity kappas, but not sure which ones to get. I could easily cut out the 6x9 shape in the rears, but is it worth the time and little extra money? I know Kappas are one of the best speakers around and will be pushing speakers at there RMS.
Thanks for your help.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 544
Do you have subs? If you don't have subs and want to add a little bass the 6X9's will work, but if you have subs just front speakers will do nicely. However if you have subs and you want rear fill I would stick with the 6.5's
Tucson, AZ USA
I have subs, but didn't know if 30 watts extra would be a big diffrence.
i will just stick to my 6.5
Thanks for the help
