Bass Blockers
Username: Mtxman06
Post Number: 9
If all i want my inside speakers to do is produce treble and my subs provide the bass, should i just get some bass blockers for my inside speakers?
Username: Araknid
BOCA , FL U.S.
Post Number: 453
you can hook up your mids and highs to a crossover.
ThatGuyYouKnow
yes you could addon "bass Blockers" all they do is -<#>db to whatever fqz and lower.
you could also buy a crossover.
its up to you. do research.
Username: Carguy
Post Number: 2576
For midrange and highs, you will need 113mf non polarized capapcitor for 300Hz filtering.
It should cost around $2.
Username: Msully701
Stratford, Connecticut US
Post Number: 68
well if you have a seperate amp for the speakers, just set the amp to HI so all it recieves is the hi frequency's and no bass would go through, like my amp has HI/LO/BOTH which basically means PURE TREBLE/PURE BASS/BOTH MIXED
Username: Mtxman06
Post Number: 10
I think im going to go ahead and buy a crossover. I have around 50 bucks to spend on it, and i can buy off ebay so things are alot cheaper. I do want to hook up both my 5 1/2 and my 6x9 with it. Thanks
