Posted on what is the difference between the PPI A300 and PPI A300.2? is one just an older model or what? are they the same for sq wise? |
Posted on bumpy bump |
Gold Member Username: Carguy
Post Number: 2635 Registered: Nov-04
Posted on They're both good amps. The one with .2 comes with enhanced/better power supply. Other than that, no difference. |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 2641 Registered: Dec-04
Posted on a bettery power supply is the only difference. |
Posted on what do u mean a better power supply??? is that internally or from the plugs or what??? |
Bronze Member Username: 1stimer
Post Number: 26 Registered: Mar-05
Posted on Thought I read somewhere that the a300 had some heat issues which were ironed out with the .2 version, but I am no expert. |
