Will 200Watts RMS Underpower a Single Type-R 122D?
HelpTheSubless
I've got a Monoblock KX400.1 400@2ohms, 200@4ohms.
Would it hurt a DVC 2ohm Type-R that has a 300Watts RMS being fed by 200Watts @ 4ohms. Im gonna go with a ported @ 28Hz.
Username: Taylor17
Kopperl, Texas
Post Number: 1566
Nope, will be fine.
HelpTheSubless
Thanks for replying man.
Considering that the sub's gonna be underpowered, do i need to modify the size of the enclosure or anything? I dont know if i should follow the suggested size from Alpine though... I'm aiming for that low soft bass.
Username: Araknid
BOCA , FL U.S.
Post Number: 439
I think using lower wattage you would need a little bit smaller box to get the same affect as having 300 watts in a little bigger enclosure. but i wouldn't go through the trouble.
Username: Subfanatic
Walton, Ky
Post Number: 3019
no you need a bigger box with less watts
HelpTheSubless
So if i use the recommended size from Alpine..i wont be getting much output in terms of dbs, rite?
Username: Invain
Michigan United States
Post Number: 2129
Your really not gonna hit super numbers with a Type R ever, but with 200 watts, no, your not gonna get a crapload out of it. It will still sound good though, the Kicker is a good amp.
HelpTheSubless
ok ok.. i just need to know if its 'safe' to use the default box size or not.. i mean i dont wanna kill a brand new sub or anything..
