Question on the Atlas 12"
Username: Drpthemc
Atlanta, GA USA
ive decided to get the atlas 12" from all the comments i have recieved on which one i should get... thanks to you all...
ok the question... at ascendantaudio.com it says not to power the gold terminals... what does that mean?... how would i wire them?...and also its single voice coil 4ohm... if i get 2 of them how many ohms will there be?... if anyone has a diagram of how to hook them up thatll be great... thanks
Username: Loc_out
Post Number: 87
http://ascendantaudio.com/Atlas%20standard%20wiring.htm
Username: Jwbulger79
Florida
Post Number: 502
the atlas is a SVC 4ohm sub. two can be wired to either 2ohms or 8ohms.
the second voice coil is used to adjust the Qts.
https://www.ecoustics.com/electronics/forum/car-audio/134156.html
