Bronze Member Username: Sevin7Post Number: 40 Registered: Apr-05 | http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=18 could i use this amp on my stock 95amp altinator? ive it would consume 60 amps, leaving 35 for the rest of the cars function... ive heard differnt things, some said you need 20a, or 50a to run the normal functions in the car. If not im sure i could do 500rms? Anyone know a good 500rms amp @ 20hms , class d, and <$300?, also i want to use my existing 8 guage wire,its only 8 feet long, so it shouldnt loose much power, the jbl says i can use 4 or 8. |
Bronze Member Username: Sevin7Post Number: 43 Registered: Apr-05 | anyone wanna help me..... |
Gold Member Username: CarguyPost Number: 2569 Registered: Nov-04 | You should be fine with that amp as long as you use self control. A typical car will need much more than 35A to run electrical components. A cheap amp is MTX 6500D. It is a class D amp and gives 500w rms @ 2ohms. They used to go for $130 before. Another alternative that's cheap is Audiobahn's A8000T. |
