Is it bad to have a 2.5 fared cap with only a 1000 watt amp
krucial
is it bad to have a 2.5 fared cap with only a 1000 watt amp??
Get yourself a optima yellowtop battery and a isolator for it and you can beat for hours.
krucial
whats a isolator i dont kno much bout car audio as u can see
Username: Dankman
Granger, Indiana United States
Post Number: 126
Get one from an audio shop its kinda like a mini alternator for your extra battery, you might have to order it but it works good.
Username: Subfanatic
Walton, Ky
Post Number: 2936
a battery isolater helps your alternator power both batteries, its like adding another setof wires so u can add a new battery to your alt, you can go to autozone or pep boys to get one prolly, but no a 2.5 cap isnt bad to have a 1000 watt amp, the rule of thumb is 1 farad per 1000 watts and who ever said bigger isnt better lol
