Preamp outputs
Username: Dfresh
Post Number: 7
I'm a little confused about preamp outputs. When you connect an amp to a preamp output, does the bass/treble levels on the head unit affect the signal going out of the preamp outputs? For example, if I change the bass does that affect the bass level being sent to the amp for the subs? I'd appreciate it someone could clarify this for me. Thanks
Username: Illuminator
Post Number: 107
Yes, the tone settings on the headunit affect the signal going to the amplifier.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 9
It depends on the deck. High-end decks usually have an equilzer/crossover or both for the subwoofer channels, or preamp channels. Then they have a level adjuster so you can adjust the amp level to the specific type of music.
Username: Msully701
Stratford, Connecticut US
Post Number: 67
so would it be best to turn everything to 0 on the amp and just adjust it by the HU?
