Suggestions on 15" sub 400-800 watt range?
Username: Johnnysanz3
Post Number: 46
i have an audiobahn a8000t that is 400 watts rms at 4 ohms, and probably 600-800 watts rms at 2ohms, i havent tested it...but i want a ridiculously loud sub that will set off car alarms with that amp, any suggestions???
Username: Subfanatic
Walton, Ky
Post Number: 2909
15 inch Avalanch, 15 or 12 inch Ti
Username: Suleman36
Post Number: 879
Avalanche 15 is the way to go especially with that kinda power.
Walton, Ky
Post Number: 2912
why not a 15 ti
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 259
i think the avalanche is dual 2 ohm leaving you with a 1 or 4 ohm load and i think 400 audiobahn watts might not be anough and it seems like the amp isnt a 1 ohm amp ... so i think the avalanche is out right?
Post Number: 47
what is the rms on avalanche 15? do they have a site, cause i cant find it
Walton, Ky
Post Number: 2952
800 rms, www.ascendantaudio.com
Post Number: 50
do the avalanche come dual 4ohm?
Walton, Ky
Post Number: 2958
i do not think so, but chad is an awesome guy, maybe hell make it special for you! lol
Post Number: 51
lol...ill check into that...i was thinkin just goin with a jl 15w3v2 then what else is there that is pretty ridicously loud that i can use my amp for
