Parallel wiring help!
Username: Hellbender
Los Angeles, California USA
Post Number: 21
I have a profile clarus cl640 75 watt x 4 amp and I want to know if its ok to wire in parallel a set of 4 x 6's into my dash connected to my 5 1/4 component set in my kick panels. that would make it 110 watts rms @ 2 ohms for the front and then i would just run my rear fills at the 4 ohm 75 watt level. Would this be ok and would it sound better then just my component set by itself in the front?Also would i connect the speaker leads from the 4x6's to the crossover where the power and ground feeds go in? Thanks for any help,
Post Number: 24
Bump
Post Number: 26
anyone with any ideas? thank you
Post Number: 27
bump
Username: James1115
Wilton, Ct
Post Number: 2486
just run your components do not add in 4x6's they are not good sounding speakers. You will actually make it sound worse. More speakers isnt always better.
Post Number: 28
thank you james, will do
