Alpine amp
james1
Hello, I have recently purchased an ampline mrd m301 but at the moment i dont have a car to put it in, i am a bit worried though as i wired up the remote wire and positive and ground off a 12v battery in my house just to get a reading of 12v on the display however it didnt display anything is this because its faulty or is it because iv more than likely that the speaker output/input were not plugged in? Thankyou very much James
Username: Subfanatic
Walton, Ky
Post Number: 2889
what was the remote wired hooked to?
james1
the 12v positive terminal, have i fucked it up? cheers james
Walton, Ky
Post Number: 2891
haha, no u havent messed anything up, but as far as i know that wont cut it, u need somen to hint at the amp to turn on, as the hu's REM wire does to turn the amp on when the HU is on
james1
Thankyou very much i apriciate the quick reply
Walton, Ky
Post Number: 2894
no prob, good luck
