Audiobahn A8000T Intake Series.Good amp?
Username: Ironguard32
Post Number: 9
I am looking to buy a new amp.I have 2 old pionier x-862 760 watts max each.Would Audiobahn A8000T Intake Series be alot better. It says RMS is 800 thd 0.02.I have 2 old cr12a kickers think they are around 360RMS or 400Rms apeace.Would it be good enough to push them.Thanks for any help.
Username: Taylor17
Kopperl, Texas
Post Number: 1501
Yes, it will push them just fine... and for the money, that amp is great!
Username: Carguy
Post Number: 2456
I personally tested the A8000T amp. It performed very well during the ice cold winter. It even survived the -25 temperature and frost!
It is one of the cheapest amp you will find that will give good value for your money.
Last time I checked it was selling for $130.
Post Number: 10
Is there any other amp around $150-$185 better?
Post Number: 11
Also will 1-15"sub out kick 2-12"subs?
Username: Carguy
Post Number: 2466
You won't find too many quality amps at that price range. You're in the Sony/Pyramid/Pyle/Lanzar/Hifonics area.
Maybe some used MTX amps.
