To the person who emailed me about the rockfor punch 10 woofers
Username: Insearchofbass
Post Number: 1506
22 deep x 22 wide x 10.75 high internal = 3.00 cf and drop the sub in. Your port tune will be 36 hz with two slot ports at 8.5 inches high by 2.0 inches wide and your boxes internal length is your port depth.......so external box measurements will be 23.5 deep 23.5 wide 12.25 high this is with no center divider in the box which you wont need.
Post Number: 1507
this box is total size for both 10s just drop them in and your ready to go i gave you a box with extra bump like you wanted
Post Number: 1508
external meausurements are using 3/4 inch mdf board
Post Number: 1509
this woofer in case there was any question
http://www.rockfordfosgate.com/products/ez2rockford/ModelInfo/ModelInfo.asp?Item Key=10063579&CategoryDesc=Punch%20Subwoofers
