How much should i pay?
Username: Theceo
im new to all this stereo stuff so try not to laugh at me too much, but i went to this shop to see how much they would charge to hook up my 2 kicker subs to my 300w kenwood amp and my cd deck, and he said about 100 i think. but then he said i would probably need a bigger amp to push my kickers. is he right? do i need a bigger amp? and is he ripping me off with that price? thanks in advance.
Username: Taylor17
Kopperl, Texas
Post Number: 1497
Wich Kickers is you're amp going to, and what is the amps spec's?
Is that including wiring. That isn't bad, but you could prob do it yourself, unless you don't trust yourself.:-)
Username: Theceo
im not sure which kickers they cuz i have them in a box already but i think they had like 4 ohms each, and yea the price included wiring.
these are the specs of a newier version of my amp.
Key Features
Amplifier Type Mono Channel
Bass Boost With Bass Boost
Bridgable Not Bridgable
Power Output
RMS Power at 2 Ohms 230 W x 1
RMS Power at 4 Ohms 150 W x 1
Performance
Frequency Response 5 Hz - 200 Hz
Low - Pass Frequency 50 Hz - 200 Hz
Signal to Noise Ratio 100 dB
Bass Boost Frequency 90 Hz
Dimensions
Width 11.44 in.
Depth 7.88 in.
Height 2.19 in.
Other Features
Input Voltage 11 volt
MOSFET amp Yes
3 Way Ready No
Miscellaneous
MPN kac-719
Username: Goon
Post Number: 119
hmm even without specs i would say you would need more watts for the subs...you could puch it with that, but more than likly it would be underpowering. ok price for installation since it's including the wireing. circuit city will charge like 120 without parts. installing it isn't hard, it's a matter of looking at pictures.
goon
Username: Theceo
is installing it that easy? is there how to website somewhere you could link me to?
Username: Theceo
is this a good amp to get?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26%26item%3D7968561739& category=38638
Username: Taylor17
Kopperl, Texas
Post Number: 1502
The link didn't work for me. What is the name of the amp?
www.bcae1.com is a pretty good website to learn about car audio. Take a look at that and see what you learn!
Username: Theceo
this link should work
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39734%26item%3D5768909398 %26
Username: Theceo
Post Number: 7
Username: Goon
Post Number: 121
you are having bad luck with these links man. tell us brand and model, plus specs. we'll let you know.
goon
Username: Theceo
Post Number: 8
its a 600w kenwood amp, KAC-728S. here are specs i got off a website.
Amplifier Type Dual Channel
Bridgable Bridgable
Power Output
RMS Power at 2 Ohms 150 W x 2
RMS Power at 4 Ohms 100 W x 2
Performance
Frequency Response 5 Hz - 50000 Hz
THD at Rated RMS Power 0.08 %
Dimensions
Width 8.69 in.
Depth 11.81 in.
Height 2.19 in.
Other Features
MOSFET amp: Yes
3 Way Ready: Yes
