Ap enclosure
somethingredicolousihavetomakeup
what is the differance from slot ported?
what does it increase sq/spl?
any links to a site with how to make one?
Username: Zacdavis
Beloit, Wi
Post Number: 50
http://www.carstereo.com/help/Articles.cfm?id=31
There ya go.
Username: Zacdavis
Beloit, Wi
Post Number: 50
There ya go.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7715
aperiodic is very accurate, helps control 2nd and 3rd order harmonics, and incrases mechanical power handling for the drivers. requires a trunk with separate air space from the cabin.
-3dB down from sealed. pure SQ. not at all recommended for SPL.
http://www.elitecaraudio.com/article.php?sid=18
http://www.maximacar.com/aperiodic.htm
I use an AP box with two 12" RE trple X subs in my car. fantastic detail, but if I wanted loud, I'd go another route. The only reason the box is as loud as it is now is due to the subs I chose, and the amps pushing them. Overcame the reduced SPL of the enclosure with more power.
what??
does anyne know wat an AP enclosure is, i have heard people talkin about it but have no idea what it is
Username: Glasswolf
Post Number: 7716
AP = Aperiodic.
I know very well what they are.
read above.
Username: Glasswolf
Post Number: 7717
aperiodic gives the impression of a large sealed enclosure, by using a smaller sealed enclosure with a resistive membrane used to increase driver control. downside is reduced output. upside is better more accurate sound.
Username: Jlojko
Post Number: 46
thanks man, i was replying to zac's link above, it really didnt give much info but you helped me alot, thanks glass
Username: Glasswolf
Post Number: 7728
I think zac got the wrong link is al. it happens.
