Sub Box for Eclipse SW6123.4
Username: Newtoaudio
Post Number: 17
Hey i have a friend that has two Eclipse SW6123.4 subwoofers that we are gonna build two seperate boxes for. Could someone give me the box specifications for these? I figured a sealed box would be best, but unfortunately we don't know the box volume and whatnot.
Username: Subfanatic
Walton, Ky
Post Number: 2373
what are the specs on the subs, can u give me alink please and ill tell you
Post Number: 18
Actually i think i might have found it, but could you tell me what "Vas" is? It says 2.4 cubic feet for the Vas, but my friend and i didn't know what that was.
Username: Insearchofbass
Post Number: 1464
for what i would think you guys would want out of those subs i would do 1.80 cubic feet per sub 12.5 x 15 x 16.75 internal plus 1.5 for thickness of wood .75 mdf board comes to 14 x 16.5 x 18.25 your ports will be slot ports one of them per box 6.5 inches high by 2.0 by inches wide your boxes depth will be your depth youll be ported at about 34 hz
Post Number: 1465
that should come to about 1.50 cubic feet after the sub is dropped in ...if it was me id make one big box 12.5 x 30 x 16.75 without the split chamber internal 14 x 31.5 x 18.25 external but if you want a split chamber do the box 12.5 x 30.75 x 16.75 internal 14 x 32.25 x 18.25 external with the ports i told you
Post Number: 1466
i was wrong you want to change that slot port i forgot to account for the width of the wall included in the depth of the port you want your port 6.25 high by 2.0 wide your box is the depth of the port
