Hey subfantic
Username: Insearchofbass
Post Number: 1416
7 cubes drop the sub in. The port will be (two 8 inch high by 2.5 wide 3 inches deep) 45 hz peaked at 48 hz
Username: Subfanatic
Walton, Ky
Post Number: 2556
hmm, that sounds NCIE, you did that QUICK, ill build it either tom or the next day, any tips on getting the box in my trunk lol, and by the way, if you know, what is the best stuff to use for sealing the inside of the box, and what can i use to repair a torn surround
Post Number: 1417
yeah build it in the trunk lol. As for the sealant i always use silicon. Dont put your sub in the box right away give it 24 hrs to dry. A torn surround i forget but someone on here answered that before post it as a question again.
ps...please dont tell me you tore you eclipse ti?
Walton, Ky
Post Number: 2559
no, i have a tear in the infinity kappa, well one of them lol, would you be made if i tore the eclipse, but i usualy use silicone, but i didntknow if that was the best,
Post Number: 1418
what measurements do we have to work with in your trunk?
Walton, Ky
Post Number: 2565
uh, wait a min, ill go measure again
Walton, Ky
Post Number: 2566
34 inches wide, 22 inches deep, 18 inches tall maximum
Post Number: 1419
is this without the thickness of wood included? if so its 6.36 cf using all of that space
Walton, Ky
Post Number: 2568
thats without the woods thickness
Post Number: 1420
ok if your for sure you can make the box that size put 1.5 inches of fiberglass insulation in on the box walls and you be at about 6.94 cf of airspace that the subwoofer will see
Walton, Ky
Post Number: 2569
fiberglass insulation?
Post Number: 1421
ok does poly come in mat form thats what im lookin for you to get and staple it to the walls of the box
Post Number: 1422
1.5 inches thick
Walton, Ky
Post Number: 2571
why, what is it, and why use fiberglass, what about just mdf, what are you talking about
Post Number: 1424
its acoustic insulation i used it years ago when i built my fist subwoofer boxes to boost the airspace the woofer saw....i bought it at radioshack not sure how thick it was anymore but if its 1 inch thick i can make the box size smaller and adjust to do two layers of the acoustic stuff for 7 cf box space the sub will see
Post Number: 1426
it goes inside the enclosure stapled to the walls of the box
Walton, Ky
Post Number: 2573
what about polyfill
Post Number: 1427
if you could keep it from blowing around out of the ports you could do it but im not sure of the conversion using that.
Post Number: 1428
go to radioshack and ask about accoustic insulation ...ill see if i can find some to show you
Walton, Ky
Post Number: 2576
so u think i shoudl use this stuff your tlaking about to make it 7.0 cubic feet
Username: Pharoh
Bradford, Ontario Canada
Post Number: 160
Hey sub. Try fixing that subwoofer with some Bycicle Rubber Glue. It comes in a Small tube and ur supposed to rub it around the patches on the bycicle tube, but i the genious, decided to use it on my subwoofer. And it worked perfect, its like a strong rubber glue that comes out in a clear jelly and drys a tad green. But it honestly worked like a charm. Wierd? haha :P. I got it in a little bycicle tube repair kit thing with some patches n glue's :P
Post Number: 1429
get polyfill batting at wallmart it comes in sheets you need 1.5 inches thickness on the walls
http://forum.sounddomain.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=029100
Post Number: 1431
copy and paste the link in a new window it will work
Post Number: 1432
when you build this box be carefull if the sub reaches full excursion before the rated power you will blow the sub if you push it too hard
Post Number: 1433
my buddies piut a mtx 10 in a 4 cf box at 63 hz and pushed twice it rated power in it many many times and its fine but you never no because it puts more stress on a sub the lower the note which in my case will be 55 hz on the same amp
Post Number: 1435
ok i stand corrected read that article you want a 15 percent boost in a ported box
Walton, Ky
Post Number: 2586
im to stoned for whatever your talking about, come smoke with me lol
Post Number: 1436
i dont do that stuff sorry lol
Walton, Ky
Post Number: 2591
damn lol, you would be fun tio smoke with haha, but so do u think polyfill or the other stuff?
Post Number: 1438
ok easier idea do the box at your demensions you gave (6.36 internal and drop the sub in) and port it at 45 hz do two of the ports 8 inches high by 3 inches wide and 5 inches deep
Post Number: 1439
no poly needed this way
Post Number: 1440
Post Number: 1441
you wont really loose much sizing it down this way ...maybe 1 db
Walton, Ky
Post Number: 2599
tahts alot! lol
Post Number: 1442
lets just do it this way unless you want to make the port removeable and leave room to change the box size with poly sheets and diferent port lengths.....if not lets do it this way.....just make double sure it fits in your car before you start all this
Walton, Ky
Post Number: 2603
ok i will tom morning
Post Number: 1443
if you do do this let me know what you hit when you get it metered at a show i gaurauntee its gonna slam
Walton, Ky
Post Number: 2605
i need to find a show around here, and i am going to do this
Post Number: 1444
sweet do you think your in the 140s now with the box your using?
Walton, Ky
Post Number: 2608
easily
Post Number: 1447
we may be saying hello to 150 if were lucky
Walton, Ky
Post Number: 2611
i hope so, thats my goal, is that competitino worthy?
Post Number: 1448
you better believe it
Walton, Ky
Post Number: 2615
what calss will i be in?
Post Number: 1449
if you go in slap youll be in the 161 to 260 square inches class which could be 7 (6.5 inch) woofers 5 (8s) 3 (10s) 2 (12s) and 1 (15)
Post Number: 1450
and one (18)
Walton, Ky
Post Number: 2623
how would i fare u think?
Post Number: 1451
in the stock class you could win but in the upper level you get your butt handed to you
Walton, Ky
Post Number: 2625
haha, how come?
Post Number: 1452
cuz thats where the money comes in and modifying the car is easier
Walton, Ky
Post Number: 2626
ho, me= money=pot lol, but i want to win comps, mind u im from ky
Post Number: 1454
the loudest car at the nationals i was at last year in your class was 156 db i think
Post Number: 1455
but that was with a wall come to think of it and he would be in a different class than you i think
Walton, Ky
Post Number: 2628
any chacne i could get close to that with modding my car
Post Number: 1456
if we can get you hittin 150 you stand a good chance at some trophys not just one
Walton, Ky
Post Number: 2629
haha YA
Post Number: 1457
i want you to get metered with the box this way then i wanna try the baffle idea which would mean adding a board internally in the sub box....well make it removeable just in case
Walton, Ky
Post Number: 2630
what, but ill be back tom, im tired
Post Number: 1458
yeah i was gonna go too later bud
