Hey anyone has instructions to take apart the faceplate? Mine's been gathering dust on the otherside of the screen and i really need to clean it out! I've taken out all the screws and pried the back and front piece apart..but it just wont come off. There's something dats still stuck and i cant find it. Anyone got any suggestions?
Yeah I'd like to do the same with my 7831. The rotary volume has gone wacky and I would like to see if I can fix it with a bit of electrical cleaner.
Anyone ever try to clean a pot/encoder like this? I should be getting a new h/u tomorrow and sure would like to give this thing to someone as a gift. It would be nice if I could make the attempt while its still a part of my system.
-Fishy
dustins
Ah..it could have been pressure fitted. Okay, i'll try that when i get back home.
dustins
No luck, the knob felt solid and wouldn't give. I'm really starting to get frustrated. I've only had the HU since december and i dont want to use any force more than necessary.. its still brand new and i definately do not want to break anything.
dustins
*sigh.. i give up I surrender to the dussssttt....
