Cheapest place to buy 4 jl w6v2
Username: Mcazayoux
New roads, La United states
Post Number: 24
subfanatic talked me into these but i have no idea where to get them at the best price so any help is appreciated. also what kind of boxes should i go with
Username: James1115
Wilton, Ct
Post Number: 2376
EBAY but remember any JL product bought over the internet has no warranty.
Username: Mcazayoux
Post Number: 25
do you think it is still worth it 2 get off the internet
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 432
If you buy them at a retailer you are going to get assrammed. I would buy them from eBay, but make sure it is from a good seller with good feed back so you don't get jipped.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 433
How dumb is that, the filters on this site won't let you type feed back as one word..g@y.
Username: Mcazayoux
Post Number: 26
thanx dude
Username: Mcazayoux
Post Number: 27
which amps would you suggest i hav a pretty good budget
Username: Tpizzle
Post Number: 92
damn you must if your goin with 4 jl's. what kind of car you got?
Username: Mcazayoux
Post Number: 29
99 F-150
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 440
Ext Cab? And if so, are you just going to cover it up?
Username: Mcazayoux
Post Number: 33
ext cab yea. what do you mean cover it up
Username: James1115
Wilton, Ct
Post Number: 2380
I believe he meant cover the bed! I would run two JL 1000/1's if you have the budget.
Username: Mcazayoux
Post Number: 35
i can't fit those under the back seats?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 444
Either that or are you going to build a wall in the ext cab. I have one 10" in a Silverado Ext Cab, and it's more than adequate. I still want an Atlas though.
Username: Mcazayoux
Post Number: 36
so would you suggest not putting them under the seats or what?
Username: Mcazayoux
Post Number: 37
o yea and Longo, im not sure if it extends that much. what else would u suggest?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 446
It would be a fit. You probably have like 9" depth under that seat. I don't know how deep those subs are, but you would also have account for the box. It would be tight.
Username: Rhassler
Gilford, NH
Post Number: 134
i have two amps under my seats of my 97 f-150 lariat..... dunno if that helps lol
Username: Mcazayoux
Post Number: 38
what kind of box would u do?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 448
You could always put some washers under the bolts of the back seats to add some height.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 449
With those subs you have to go sealed, good rich sound. Sealed all the way, plus the sealed box will be smaller than a ported box.
Username: Mcazayoux
Post Number: 40
Thanx. So how do you think all this sh** will sound?
Username: Mcazayoux
Post Number: 41
And by the way thats a fu**in great idea about the washers.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 451
The W6V2 are awesome subs. You'll have one hell of a system if it's set up correctly. The major issue will be those subs. I don't know the mounting depth of those subs, but I think they will fit. You will want to do seperate chambers so the subs have their own air space.
Username: Mcazayoux
Post Number: 43
alright. where can i find out the measurements?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 453
You should be able to find them on JL's website.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 338
the depth of thoes are just shy of 8 inches
Username: Mcazayoux
Post Number: 44
Power Handling:
800W Continuous
Drivers:
Two 10W6v2
Final Impedance:
4 Ohms Mono
Dimensions:
12.75"H x 30.00"W x 11.35"D
Notes:
Sealed enclosure
rear-firing design
what do you think about that for box deminsions?
Stockbridge, GA USA
Post Number: 339
well, for the 12's anyway. idk what size your talking about
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 461
Michael, you'll have to build a custom box. And you'll most like have to try and raise your seat a little bit. They may make prefab boxes for your style of trcuk, as know they make them for mine.
Username: Mcazayoux
Post Number: 45
alright thanx, ill have to find out how 2 build one. prefab?
Username: Mcazayoux
Post Number: 46
whats that?
Username: James1115
Wilton, Ct
Post Number: 2383
pre-made. I would not put washers in the bolts of the back seats if you ever plan on having passangers back there, if you were to get into an accident that would completely compramise the integrity of the bolts and there ability to hold that seat from flying forward, or out. It sounds like a good idea but I would not recomend it at all.
Username: Mcazayoux
Post Number: 48
sh!t. thanx, so do u think i could find a premade box that could fit under my truck?
Username: James1115
Wilton, Ct
Post Number: 2386
if they make one which I am sure they do for that truck. I would go custom with those subs over pre-fabbed. Pre-fabbed boxes have a tendensy to be sh!tty.
Username: Mcazayoux
Post Number: 51
thanx man i appreciate all this sh!t.
Username: James1115
Wilton, Ct
Post Number: 2389
no prob.
Username: Subfanatic
Walton, Ky
Post Number: 2416
did i really talk you into this? but if your intersted, ill build you custom boxes for your truck
Username: James1115
Wilton, Ct
Post Number: 2394
yeah after soming a 1/2 pd of herb! lol I would really want that box lol! I'm j/k sub:-)
Username: James1115
Wilton, Ct
Post Number: 2395
that was supposed to say smokin I have no idea what happened there lol!
Walton, Ky
Post Number: 2420
what are you talking about james, im confused as f
Username: James1115
Wilton, Ct
Post Number: 2396
nothing sub just puff one down for me:-)
Walton, Ky
Post Number: 2422
dude, im done smokeing, i get caught to much lol
Username: Mcazayoux
Post Number: 52
hey sub, how much u think those boxes would cost me?
Walton, Ky
Post Number: 2438
uh for 4 12's ill do 100 plus shipping for all custom boxes
Username: Mcazayoux
Post Number: 53
awesome thanx
Username: Mcazayoux
Post Number: 57
how much would shipping be sub?
Walton, Ky
Post Number: 2497
50 or 60 bucks maybe, it depends on how big the boxes would be but i live in 41094, and the boxes would be in my opinion around 50 or 60 or 70 or 80 lbs lol
Username: Mcazayoux
Post Number: 58
thanx
Walton, Ky
Post Number: 2508
if u want michael, if you want to do this deal, 150 for everything, ill pay shipping with it if you want
Username: James1115
Wilton, Ct
Post Number: 2415
sub you are gonna get killed on that deal. shipping alone on that thing is gonna be $80-$100!
Walton, Ky
Post Number: 2526
i dont care, whatever helps him out!, i maek enough selling lol
